It is currently Wed Aug 20, 2025 1:39 pm
 Post subject: neck to body
PostPosted: Sun Mar 23, 2014 3:07 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
On a wedge type body how are you handling the neck to body joint??
MK5acoustics.com
 Post subject: Re: neck to body
PostPosted: Sun Mar 23, 2014 3:23 pm
Why would it be any different?
PostPosted: Sun Mar 23, 2014 4:31 pm
Same at the top, angled laterally at the heel. I presume this is what you are asking about weslewis?
PostPosted: Sun Mar 23, 2014 5:33 pm
First name: Trevor
Last Name: Gore
City: Sydney
Almost exactly the same. Just bevel the heel cap to match the back slope.
http://www.goreguitars.com.au
PostPosted: Sun Mar 23, 2014 6:06 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
here is what I did...in retopping this 12 string that I am working on, I induced a slight wedge so I enhanced the wedge to give it a try, that's when I started thinking about the neck joint, I can see angling the mortise when building a wedge to match the tenon , problem is the neck block is in place and the mortise is already perpendicular to the previous top and the bolt holes are already drilled so if I cut the tenon like I normally do on a table saw at 90 degree angles things wont match up right...my plan is to use a taper jig and cut the tenon offset , if this makes any sense.....
so I was just wondering how you guys were tackling this angle during the build...
MK5acoustics.com
PostPosted: Sun Mar 23, 2014 7:01 pm
Sounds like you need to cut the tenon at the same angle as the wedged top ...
PostPosted: Sun Mar 23, 2014 7:12 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
yes..
MK5acoustics.com
PostPosted: Sun Mar 23, 2014 9:38 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
actually it was no big deal...I made a ply extension for my incra mitre guage cut the tenon at 2 degrees off set then set my table saw blade at a 5 degree angle and finished like normal...
MK5acoustics.com
PostPosted: Sun Mar 23, 2014 10:13 pm
First name: Trevor
Last Name: Gore
City: Sydney
On a new build, it's definitely easier to put the wedge on the back rather than the front, then all my usual tooling continues to work. Just need to finish off with the angled heel cap.
PostPosted: Sun Mar 23, 2014 10:25 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
that definitely makes sense....this being a rebuild ...just kinda ended up that way!!! gaah gaah gaah laughing6-hehe laughing6-hehe
coming out nice though , same one I mentioned on the anzlf site...using falcate bracing
MK5acoustics.com
